WehuntSam
Oct 09, 2019Explorer
Need help understanding Truck Capabilities
In 2001 I purchased a 2001 Silverado 1500 HD Crew Cab 4x4 for the specific purpose of adding a slide-in truck camper. I was soon discouraged when all the camper dealers told me that my “1/2 ton” truck was not capable of carrying any of their units available in 2001.
This was very confusing as the truck is equipped with eight-lug wheels and a 6.0 liter V8. I believe it has a larger braking system as well. All of the available reviews on the 2001 1500 HD clearly state that the truck is in fact a ¾ ton with ½ ton badging.
Further research indicates that the only difference between the 1500 HD and the 2001 -2500 Silverado was one leaf spring.
The Vehicle Weight Limits shown on the sticker reads:
GVWR = 8600 LBS
GAWR FRONT = 4410 LBS
GAWR REAR = 6000
The Camper Sticker in the glove compartment reads:
CARGO WEIGHT RATING = 1949 LBS
DIMENSION A = 68 INCHES
DIMENSION B = 32 INCHES
I found additional information on the Auto channel review of the truck in 2001:
Curb Weight
5,600 lbs
Gross Vehicle Weight Rating
8,600 lbs
Max Payload
3,000 lbs
I weighed the truck at a local salvage yard and the 5600 lb. curb weight is accurate.
What is the maximum dry weight and wet weight can I safely use with this truck?
My preferred camper is the Cirrus 720 with minimum options adding 132 lbs. to the 1875 lb. base dry weight for a total dry weight of 2007 lbs.
What are Dimension A and B ?
All help appreciated.
GVWR = 8600 LBS
GAWR REAR = 6000
Curb Weight
5,600 lbs
8,600 lbs
Max Payload
3,000 lbs
