rferoni's avatar
rferoni
need water damage repair guidance on first TT..
Hey all,
I apologize if this isn't in the right forum. Not really sure where to put the question. Sort of surprises me there isn't a repair only forum?
So I finally purchased my first TT. Didn't know it had water damage so now I have to fix it. Damage is in back corners of TT.
I more need info on best materials to use. It is a 2003 Coachman Cascade 26' bunkhouse. Aluminum siding with rubber roof.
Fixing the wood rot is actually the least of my concerns. I'm more concerned with sealing it back up while putting it back together. My plan is the following....
1. Use 100% butyl tape on corner moldings
2. Use stainless screws to put the moldings back on
3. Use stainless or aluminum staples for the siding(do they make aluminum staples?)
4. Use decking screws for all wood repairs.
Should I also caulk around the moldings after fastened with the butyl tape? If so what type of caulk?
I need to seal a bunch of the clearance/marker lights also. Can I use the butyl tape for this?
Would appreciate any advice. Am I headed in the right direction?
Thanks,
Ron
