ChrispyjCSLT22 wrote:
This is alot of perspective to consider, and I'm appreciative of it, but I'm trying to avoid getting/using a generator and lugging around gas cans..
I get what you say about run time but would running the AC on low would help?
No, low only affects the fan speed, the fan compared to the compressor draws a smaller portion of the power used.
Additionally, running the fan on low speed in high humidity areas is a recipe for frost/freeze buildup on the A/C coils which leads to restricting your A/Cs cooling effect wasting energy in the end.
Outdoor temps and humidity levels can and does affect not only the cooling performance but also how much power is drawn by the A/C. The higher the temp the higher the current draw will be. The higher the humidity level, the longer the compressor has to run to make the humidity levels drop inside to make you feel comfortable.
Running an A/C for short bursts of time can often backfire and use more energy than if you just allowed it to run continuously but set the T stat up a degree or two.
The compressor is the energy hog, absolutely nothing can change that.
Like I mentioned, you might perhaps get an half hr to one hr of A/C, but the issue becomes just how much energy will you use above that every day and just how much energy you can harvest in the 5 peak sun hrs per day.. Just because it is daylight, it doesn't mean the solar panels are charging.. They have to be illuminated with enough light to generate enough voltage above the battery voltage in order to charge the battery.. But it can take a good bit of voltage above the battery to get maximum possible charging.
The system is undersized in all directions, solar and battery if you want more than a hr of A/C per 24hrs..
As far as lugging around gas cans goes, it makes it sound like you really want to run the A/C longer than a hour..
Typically most gens in 3.5Kw size will use .5 gallon per hr (yes, that is a half gallon) or a bit less, most gens the tanks are sized to allow run times for about 10-12hrs at half load.
So unless you were planning to run the gen 24/7 you may not need to deal with a bunch of gas cans..
Lower wattage gens often will use less fuel per hr and the fuel tanks are also typically sized for 10-12hrs run time but there is a fine line on gen sizes that you have to watch, too low of wattage and it won't start and run a A/C reliably.
Solar and batteries have improved, but it still takes a lot more of both plus money than the system built into the RVs you are looking for.
Back of the napkin math I did for another run A/C on battery and solar thread was 4,000W of solar, 9,600Ahr of battery for 24/7/365 A/C use. The system would cost $29,824, weigh 3,500 lbs with Lithium batteries.
The solar panels would require 320 sq ft of roof space (equivalent to a 40ft long RV 8ft wide) and batteries would need about 40 sq ft of storage space.
And that gets you enough battery capacity just for the A/C unit for operation of three days with no sun.. Doesn't include what you need for other camping needs..
I can buy a nice gen and a lot of fuel for $30K and it wouldn't weigh 3,500 lbs..
