pjkdog's avatar
pjkdog
Newbie Question about Trailer Hitch Purchased with Trailer
Hi Guys,
My wife and I finally made the plunge and purchased a Starcraft Launch Mini 19BHS.
I have a Ram 1500 with the factory installed trailering package, so it has a receiver, a there is already a trailer break setup on the dash.
When I bought the trailer(which we still have to pick up as it's being prepped for delivery)
I said I wanted a good anti-sway system and the guy added a blue ox pro. These were the options.
1) Blue Ox Sway Pro $830.00 Installed and Demonstrated by technician
2) Reese/Husky WD with Sway Control $585.00 Installed and Demonstrated by technician
Is this typical, is it a good hitch and price? I am totally fresh to this whole thing, I studied the campers, the hitches not so much but any advice is appreciated as we have not picked it up yet and could still make changes.
  • Unfortunately you haven't indicated just which Reese system this might be, whether it requires the use of a separate friction sway bar or whether it's a WD system with integrated sway control, as is the case with the Blue Ox Sway Pro. Hard to go wrong with the Sway Pro if you can afford it. Regardless, keep in mind that it's difficult at best to properly set up any weight distribution system on an empty trailer and you may well have to make your own adjustments to it once you've figured out how you're going to best load your new trailer for camping.
  • Thank you, the dealership is pretty well rated, and my guess is they do this install a lot but I will for sure ask plenty of questions!
  • It's a pretty well regarded option, up there with Equalizer and Reese Dual Cam. The pricing seems reasonable IF they set it up correctly. It runs ~$600-650 on Amazon and etrailer so charging ~$200 for install and customer training seems pretty reasonable given that install is probably an hour and customer training could be 30 minutes. I would read the manual and ask them about the setup, many have reported that their dealership did not correctly install their WDH in which case it can actually make towing worse and I personally would be pissed to spend $200 on a bad install.
