Brox wrote:
I mean as equipt with full propane tv and acc.Just no water or are supplys
My dry weight trailer of 4370 lbs actually weighs 6006 lbs when loaded without water.
I suspect you are way-over weight on your Liberty
I started with a 2012 Acadia similar tow rating to your Liberty
Trailer Max Weight 5200 lbs
Tongue Weight max 600 lbs
GCWR 10,450 lbs
GVWR 6,459 lbs
Payload 1397 lbs
Therefore with my 6006 lb trailer with 750 lbs of tongue weight I would be way over already with a trailer similar to your trailers weight when dry.
If I fully load my Acadia with my family, cargo, fuel, and tongue weight (which is already over my hitch rating) then I would be at or exceed my GVWR of 6459 lbs. Assuming that I'm AT the GVWR of 6459 lbs then my allowable trailer weight would be limited to 3991 lbs. Since Gross combined Weight Rating GCWR is 10,450 lbs minus the loaded weight of the Acadia GVWR at 6,459 lbs equals 3991 lbs remaining for the trailer. So for me to tow my similar trailer (slightly heavier) with my Acadia (slightly higher rating then your Liberty) I am WAY over on payload, max trailer, max combined, max tongue.....
Just my .02 cents but the Liberty is unable to handle the weight and the Cherokee is too old to trust the original ratings.
I learned an expensive lesson when I purchased my TT, thought that 4370 lbs behind an SUV rated for 5200 lbs was a no brainer. I learned that I needed a pickup truck. My 1/2 ton Sierra is at the Limit for my current trailer and it is actually rated to handle 9500 lbs.
