TurnThePage's avatar
TurnThePage
Not sure if I have an issue or not...
2015 Ram 1500 Laramie with OEM integrated brake controller. Last weekend was the first tow of the year.
In the past I could have sworn that when the trailer was connected, there was a small trailer icon on the dash. Now there's none. Aside from that, everything appears to be working correctly. Braking is good, and all the lights are doing what they're supposed to, and the various trailer settings are still available in the menu.
I'm also noticing that the fog light indicator/icon is always on when the lights are on now too.
  • Nah, it's not that one. It's not a warning light so much as an indicator that the trailer is connected. When I would disconnect, there would temporarily be one like this.
  • My Yukon had a trailer like that when tow/haul was "on". I am almost positive that my RAM truck just says "tow/haul", and I have to turn it on, it doesn't come on automatically when there is a trailer attached.
  • On my 2017 Ram, it comes on initially in the center of the gauge cluster (where the digital speedometer and other info is displayed). It alerts you initially that the trailer is hooked up, but after that, it goes away.
    It will come on again if you squeeze the levers on the manual brake for the brake controller.
    Mike
  • Funny on the 2016 RAM SLT, I only get a message on the EVIC that trailer is connected and "Check Settings".
    Mike
    I'm pretty sure mine does exactly this as well. It also shows the "no trailer" light momentarily after disconnecting the trailer.
