specta's avatar
specta
Over weight? Does it bother you?
From spending time in here lots of people have said that they were over weight with the camper.
I'm over weight.
Does it worry you? Does it keep you from going where you want to go?
How much "cushion" do you think the truck and tire manufactures build into their products?
5%? 10%? 15%? 20%?
I have no worries about the capability of my truck or tires nor do I believe that I'm unsafe.
How about you?
  • stumper92 wrote:
    With my previous truck I was over my GVWR by a good bit. However, I was under my axle weight, and tire ratings. I was not a fan of it but did not feel unsafe. My biggest concern was liability should I get into an accident. I believe if you stay within your axle and tire limits, and drive like you have some sense, you are safe.
    This.
  • I was 30% over the GVWR for my first rig. I used it full time for a couple of years and several months a year for 5 more years. I had a Ram 2500 with a rating just under 10K pounds. The equivalent 3500 differed by wheel size and had one more spring in the rear. I improved the handling and capability of my truck with airbags and Supersprings. Eventually I also upgraded wheels and tires to 19.5s.
    I really had no concern about the weight for the axles and truck in general. Tires were a different situation. In hindsight I should have upgraded tires immediately. Instead I ran through a couple of sets of tires and went 60K miles in the range of 5-10% over the tire ratings.
    Just a couple more comments when it comes to tires. LT tires are rated differently than passenger tires. An LT tire is rated to carry the maximum load for the life of the tire. There is a considerable margin built in to the rating. The rating does include a safety margin BUT...... Tire performance is highly dependent on maintaining proper pressure. I always checked my TPMS to be sure the tires were properly inflated. Low pressure will cause a rapid build up of heat and quickly damages a tire. Secondly, tire performance is highly dependent on how the tires are used. Many RVs sit for long periods of time with little or no use. That is extremely hard on the tires. Dry rot occurs rapidly when a tire is NOT being used. I almost learned this the hard way. After 4 years under the bed of the truck, I put my spare into rotation. It looked fine when I put it on the truck. It sat in the driveway for a few weeks while I was preparing for a trip. In that time the dry rot became evident and the whole tire was covered with deep cracks.
    Again, I no longer push the load rating for tires. In addition I am fanatic about tire pressure and I will not use a tire that might have dry rot due to age or lack of use.
  • With my previous truck I was over my GVWR by a good bit. However, I was under my axle weight, and tire ratings. I was not a fan of it but did not feel unsafe. My biggest concern was liability should I get into an accident. I believe if you stay within your axle and tire limits, and drive like you have some sense, you are safe.
  • Im over length too but I don’t worry about it, its no one else business.
  • Details matter. How well distributed is the weight? Is the rear axle MASSIVELY overweight while the front axle is lighter with the camper on than it is without it?
    Being a little overweight shortens the life span of components. You might, for example, find yourself changing brake pads and shocks more frequently.
    Being a LOT overweight is dangerous.
