partsman01
Apr 14, 2015Explorer
Inspect the brake controller wiring harness jumper that is plugged into the vehicle relay block-body. The relay block-body is located under the left side of the instrument panel near the left kick panel, behind a plastic cover.
The 1999 though early 2003 wiring harness jumper that plugs into the relay block will have a reddish/brown 6-way connector and a tag with the last four digits of the wiring harness part number. Second design 2003–05 may have a white plastic connector with part number 5418 as well.
The 1999 jumper is/was P/N?12171982 with a pink/purple tag identifier of 1982. This number has been superseded to 15366255, with a pink/purple tag identifier of 6255.
The 2000 jumper harness is P/N?15366255. The pink/purple tag identifier is 6255.
The 2001-2002 jumper is P/N?15086884. The orange tag identifier is 6884.
The 2003–05 jumper is P/N?15085418. The orange tag identifier is 5418.
When transferring the brake controller with the wiring jumper attached from a 2001-2002 vehicle to a 2003–05 vehicle, a change to the jumper harness connector must be performed.
Object ID: 366012Click here for detailed picture of the image.
