partsman01
Apr 14, 2015Explorer
The following information is for the 1999-2002 wiring harnesses.
Pin
Wire Color
Circuit Number
Function
A
LT BLUE
1620
Stop lamps
B
RED
142
Brake controller 12?volt source
C
DK BLUE
47
Brake Controller output (Trailer Brakes)
D
BROWN
2409
Brake controller illumination
E
F
BLACK
1850
Ground
The following information is for the 2003–05 wiring harness.
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
B
RED
242
C
DK BLUE
47
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
To modify a 12171982, 15366255 or 15086884 harness for use in a 2003–05 vehicle, switch the wires in cavities “A” and “D”.
To modify a 15085418 harness for use in a 1999-2002 vehicle (see model list at the front of this bulletin for applicable models), switch the wires in cavities “A” and “D”.
Warranty Information
When the correct wiring harness P/N is matched to the specific model year of the vehicle, everything works properly. Therefore, conversion of an incorrect wiring jumper to match the vehicle would not be considered a warrantable repair.
Pin
Wire Color
Circuit Number
Function
A
LT BLUE
1620
Stop lamps
B
RED
142
C
DK BLUE
47
D
BROWN
2409
E
F
BLACK
1850
Ground
Pin
Wire Color
Circuit Number
Function
A
BROWN
2409
B
RED
242
C
DK BLUE
47
D
LT BLUE
1620
Stop Lamps
E
F
BLACK
1850
Ground
