Steve_in_29 wrote:
Geewizard wrote:
What you need to do is buy a pickup that isn't labeled as a 1/2 or 3/4 ton pickup....like a Toyota Tundra double cab 4x4. Then you can put whatever you want on it and you're good to go!
That tongue-in-cheek comment is just that. I'm 500-700 lbs over the cargo capacity of my Tundra. Have been since 2004 and 110,000 miles ago. Guess that makes my Tundra a 1-ton pickup. :B
And I have a bathroom.
PM me if you want details.
Full disclosure don't you have the smaller version of the Apex designed for Toyotas. Does Outfitter still make that one?
Your 5-700lb overage, while not ideal, isn't that bad on a 1/2 ton but pretty much all the other bathroom equipped campers would be well over 1000lbs too heavy.
Full disclosure:
I wanted the Outfitter Apex 8 for my soon to be purchased 2004 Toyota Tundra Double Cab 4x4. I had Outfitter go to the Longmont, CO Toyota dealer and measure the distance between the wheel wells in the bed of a 2004 Toyota Tundra Double Cab 4x4 with the factory plastic bed liner. Outfitter then custom-built an Outfitter Apex 8 to fit. In doing so, they narrowed down the width of just the "tub" portion about 1". The length of the "tub" is the same as a stock one. Fresh, grey, and black water tanks are the standard size. Earlier year Tundras had smaller bed dimensions and therefore needed more "downsizing" of an Outfitter Apex 8 in order to fit.
I had Outfitter add two Goodyear Ride-Rite airbags to the Tundra with manual fill valves, a Honda EU-2000 generator, microwave with MSW inverter, two overhead cabinets, 30-lb propane cylinder, Fantastic fan, Seitz double pane hinged windows, ladder, folding rear steps, and roof basket.
Later on, I removed the 3-way fridge and installed a Tundra TJ42 fridge, removed the microwave and MSW inverter (the microwave space freed up now stores my small propane BBQ), installed a Xantrex pure sinewave inverter (1000W), 120W solar panel with Morningstar MPPT controller, Xantrex Link 20 battery monitor, an additional 105 AH battery, marine battery switch, Air Lift wireless compressor for the air bags, and removed the roof basket. I now carry a 100W portable solar panel as well.
By the way, I have been in several panic braking situations with the TC on the truck and never had issues with braking. No fade, no nothing. The brakes on my Tundra are quite adequate for the load in a panic situation.
(this post edited to include more information from Outfitter regarding my "custom" fit).
