MM49
Jan 13, 2015Explorer
The 2500 will give you the most stability towing. The five link rear suspension preforms better than leaf suspension. The lateral movement is greatly reduced. The question on diesel vs. gas engine is less important. The heavier engine might provide a slight increase in stability at the cost of payload. The greatest benefit is the coil spring suspension.
MM49
MM49
44,066 PostsLatest Activity: Apr 10, 2026
