MM49
Jan 13, 2015Explorer
ib516 wrote:You won't notice the stability difference pulling a fifth wheel. You will notice it pulling a TT. There are greater demands pulling TT. I switched from a diesel to the coil spring 2500. A Very big difference. My 2500 will pull a 29'.7" tt almost as well as fifth wheel. It is so good that I would never consider buying a fifth wheel to improve towing. There are just no problems, sway, push or any other disturbance.
I don't think you'd notice any difference in stability. I have driven my 2500 towing a 14,000# 5er, and been a passenger in my buddy's 2014 3500 SRW Cummins towing the same 14,000# RV 5 min later. The difference in chassis and suspension was discernible, but not unless you were in them back to back, and even then it wasn't huge.
There is more of a difference in powertrain performance between the gas and diesel, but either would tow the two RVs you mention pretty easily.
I was am in the same situation as you (tow only for holidays in the summer), and I chose the Hemi and haven't regretted it one minute.
MM49
44,066 PostsLatest Activity: Apr 10, 2026
