falconman515's avatar
falconman515
Range Hood and Power/Water Wall Meter just stopped working?
So I had my trailer all good to go and everything worked on the the last trip out a month or two ago ... going camping this weekend, picked up the trailer from storage, turned everything on to make sure all was well and out of nowhere the range hood light/fan will not come on and also the wall mounted water and power meter doesn't work (the one where you press the button for 12v/fresh/black water and it gives you lights to tell you what your levels are).
The lights, radio, water pump switch (that's actually located on the 12v/water meter) all works.
I pulled the fuses all looks fine there ... kicked the breaker and turned it back on and nothing ... tried disconnecting shore power and plugging in my truck (since i have the batteries in the garage charging) to see if it would do anything different running straight 12v and Still Nothing!?!?!?!
Any suggestions on what this may be?
I notice now to that the LP alarm beeps every time I unplug the shore power and beeps a whole bunch of times when I turn it back on ... kinda like it's resetting .... nothing funny other then the fact that it never did that before is all.
I am not hugely worried about the 12v/water meter (though I for sure want it working if at all possible) but the wife really needs the over the range light and fan for cooking.
Any help here would be greatly appreciated guys! :)
Thanks so much.
-Chris
