tama2112's avatar
tama2112
Redwood or Jayco - are both viable options for my truck?
Hello,
After much deliberation, I decided to scratch the Augusta Ambition 5th Wheel as I agree it was just too much for my truck. I appreciate everyone's input. I have narrowed my search down to two options and would like to get your thoughts based on my truck. Here are the specs one more time:
2016 GMC Sierra 3500 SRW.
- CREW CAB, STANDARD BOX
- Axle Ratio: 3.73
- Max Towing Capacity: 17,200 lbs
- Door Sticker: Combined weight of occupants and cargo should never exceed 3,594 lbs.
- Tires: Max Load Single: 3,525 lbs (Load Range E)
OPTION A:
Redwood 3991RD
Dry Weight: 14,938 lbs
GVWR: 17,900
Hitch Weight: 2,650 lbs
Length: 41' 5"
OPTION B:
Jayco Designer 39FL
Dry Weight: 14,815 lbs
GVWR: 17,995
Hitch Weight: 3,065 lbs
Length: 41' 6"
I will not be full-timing in this, so I really don't think Ill be adding 3,000 lbs of weight.. I unloaded everything from my Motorhome today and didn't even fill up a 5 ft x 5 ft storage unit. Granted that didn't include clothes or food (or whiskey).
The pin weight of the Jayco has me a little nervous. Can I ask for your input?
Thank you!
Matthew
