coolbreeze01
May 05, 2016Explorer
busterbrown73 wrote:
I read that upgrading to a d-rated tire with higher max pressures on the OEM wheels can cause failures in the alloy material of the wheel itself.
I don't believe D or E rated tire pressures would cause a rim failure.
If you go to the expense of going with larger wheels, check into 16".
44,068 PostsLatest Activity: Jun 01, 2026
