rbpru
May 08, 2016Explorer II
I talked to the tire dealer about rim pressure and rubber valve cores. He said not an issues in the 50 to 65 psi range. Above 65 psi cold he would go with steel valve cores.
He had no comment on the rims above 65 psi. Why should he, they have no idea what rims you have on your TT or why and how you want to treat them.
When you deviate from what the manufacturers recommend you are on your own.
44,068 PostsLatest Activity: Jun 27, 2026
