busterbrown73
May 11, 2016Explorer
Huntindog wrote:
If you are willing to go to larger rims, skip the 15s and go to 16s. I wish I had.
There will likely be some challenges to doing this, but the only one that is pretty much a deal breaker is the distance between the tires.
You need 1 inch. I doubt that this will be an issue for you as that is pretty much dependant on the length of the springs, and that is pretty much standard in the industry.
You will need 3" from the top of the tires to the wheelwells. If you need to, a small lift can be installed. Either an spring over axle or lift blocks will work fine.
You will most certainly need 6 lug drums to match the new 6 lug rims. These are not nearly as expensive as I thought they would be. Do it at bearing packing time to make the job and expense easier.
Then get a quality LT tire and not worry about all of the ST tire limitations.
Upgrading to 15's is no problem. I checked a tire calculator to convert my 205/75/14's to 225/75/15's. I need just 2 extra inches in total diameter for the new tire and about 1 inch clearance under the wheel well. 16's may work but I'd have to measure for sure. Having LT tires would be ideal too. My biggest thing is the axle limitations. If I change out the hubs and drums, wouldn't it be advisable to just change out the axles to something more stout? Not that I would ever want to go over the GVWR of the trailer, but it would be nice to have that extra capacity as a reserve. Otherwise, the axles become the weak link in the chain.
44,068 PostsLatest Activity: Jun 27, 2026
