- GrandpaKipExplorer IIWhy take the chance? Supporting the awning ends should only take a couple of minutes.
- Colo_NativeExplorerI just replaced one of the brackets in mine and if you open the awning and support it (I use bungees tied to a 12" ladder) take all the pressure of the strut (shock)
- VulcanmarsExplorer
MFL wrote:
napanee ted wrote:
I would like to know if when changing the gas shocks on my awning should I support the awning end that I am working on before removing the shock
While you are not giving much info on awning type/brand, I would support my Dometic electric awning before removing the shock. If I pull down to lower the awning end, it seems the shock is doing a lot of supporting. I have to say, that I have never replaced one though.
Jerry
X2- Need more info.
Mine (Lippert) are rated at 124 lbs. You need to support the end. - MFLNomad II
Jerry - LwiddisNomad IIISupport is good.
44,066 PostsLatest Activity: Jul 25, 2018
