Seminoe Joe wrote:
D3500ram,
It looks ok the last 2 photos like the tape is under the skylight with caulking along the edge? Is that correct?
Yes,
The first two images is the original skylight bubble where I tried to EternaBond(EB) over the flange edge.  The EB  did not take to it too well over it but stuck to the roof just fine. I prepped and cleaned everything (and I mean EVERYTHING!!!) but don't know why it didn't adhere to the dome.
In order to do it right, I ended up replacing the bubble. To do this I removed the old dome to discover a slight leak had gotten in and started to deteriorate the roof frame. Ended up stripping part of the roof membrane back towards the front at the vent... I think the water came in via the vent. Then manually stripped the EB that remained on the roof (no easy task) and started fresh.
In my opinion, one should NOT install EB over the bubble flanges in case it needs to be replaced at a later date.  I lapped in the proper direction strips of EB to cover up where I peeled back the roof membrane then installed the new skylight with butyl tape.  When it was all snugged up I then used self-leveling sealant (forget whether it was GeoCel or Dicor) over the dome at the edges and over each fastener.
Part of this repair also included inspecting, prepping and resealing the vents, antenna mount as well as the rear trim atop the roof.
