Colo Native wrote:
I received my Ride Rite air bags and I bought the tee for 1 air fitting but I am not sure if I want one or rather have 2 for side to side leveling the truck sits about 1/4" difference side to side. I am not going to buy an on board compressor. Just wondering what others have done. I forgot to add where did you put the air fill?
I lasted a year on my previous truck, then installed the compressor. The new truck I installed bags, and compressor, just too many advantages to having onboard air, just the fact of adjusting on the fly to existing road conditions.
But probably the biggest advantage is knowing how much air is in them, the Ride Rite you have, have to have 5-10 psi in them , can't run them empty, it will ruin them. So that means you are checking them every time you drive the truck to be safe. My previous truck I had the air gauge in the cab, and knew at a glance what the air pressure was. My present truck I installed the wireless system, and it monitors the air pressure , maintains it to whatever I have it set at, which is 5 psi. when empty. No worries at all about running without air in them.
