Bedlam
Sep 23, 2014Moderator
If you have the upper overload spring, the StableLoad taller contact pads will make a big difference. If you need more (my camper is heavier than yours), the StableLoad wedges on the bottom spring can be added later. I'm close to you and could show you my setup. If you do not have the upper overload spring, you will need to add a supplemental spring (SuperSprings, WorkRites or Timbrems) first before making additional changes.
Stop at one of the DOT scales and get your axle weights. You will want to know how close you are to your tire capacity.
