egarant
Sep 04, 2013Nomad
Timbren's or Upper Stable-Loads
I've already searched the forum for this answer, but haven't found an answer to my satisfaction....so hear goes....
I have a 2013 DRW 4WD RAM 3500 Crew Cab with an Eagle Cap 950 on her. I put a full set of lower Stable-Loads on her prior to the install of the camper. I've also installed a set of rear Bilsteins (the front are not available yet).
All in all she rides pretty good, just a little bit of sway going in and out of driveways.
I still have some space between my front upper overload and the bump stop, the rear end of the overload is touching the bump stop.
Would and upper set of Stable-Loads or a set of Timbren's be the next step in upgrading the handling.
Thanks!
Thanks!
