languiduck
Sep 26, 2014Explorer
JW2 wrote:
Thanks all for your responses so far. I have to admit, I thought I might have received more responses then I did. Bedlam, yes I would like to take you up on your offer to see your setup. I will PM you about this.
I haven't been on here very long, but I think it is because everyone needs a break on this topic. It was just discussed in length about 3 times in as many weeks. Plus, I did a search and found this discussion comes up quite often, with the same results each discussion.
Be happy you haven't had the typical responses of:
You're overloaded on that SRW.
Go to a scale and get weighed.
You need a bigger truck.
You need 19.5 wheels.
You should have bought a truck that doesn't sag.
Fords have weak frames.
If you are wanting to try Stableloads, start with the lower ones for sure. I like mine and they made a significant improvement in sag and a more stable ride.
