ScottG's avatar
ScottG
Nomad
Aug 13, 2017
Sagging Awning Toppers - fix idea's
First off, This is not a thread for folks to exclaim how they don't like awning toppers, why they wont have them or what ever. I like them (had one on last TT) and it's going to stay.
This is a conversation for constructive ideas.
Our new TT has a long, wide slide and like so many, the awning over it sags and allows a large puddle to form when it rains.
I plan on having the dealer check it out when I bring it back for something else but I know there's litle that can be done.
I would like to hear peoples methods of combating the problem. What's your fix?
Pics welcome!
  • downtheroad wrote:
    When we had a long (super slide) with an awning I used two tether balls. They have a rope attached...(Big 5 Sporting Goods store).
    I like LarryJM's solution better. Just shove the block of foam up under the awning using a long handled window washer tool..no ladder needed.
    I use my awning rod to install the foam pieces and it can be used to pull them out since it has a right angle at the end. However, I like the rope since that allows me to position it right where I want it and then remove it easily.
    Larry
  • ScottG wrote:
    I only have about 6" of clearance so Lrry or Joe's idea's would work best.
    Joe, Do you have a way to keep the middle of your PVC from sagging?
    (I like the awning rod idea - brilliant!)
    Scott,
    I just made them and used them for the first time these past 3 weeks in Florida... We had very heavy rain almost every day with NO puddles on the topper !
    s you can see, mine did get a sag, which I saw when I removed them the day we left. I plan on cutting the bar in the middle and adding a "T" with an additional support.. I also used screws, and did not glue them together,,, ask me why ?? I had no glue handy ! !
    Since getting the automatic awnings, the bars were getting neglected :-)
  • I only have about 6" of clearance so Larry or Joe's idea's would work best.
  • I am with you Scott..
    This is the first RV we have had that has the longer slide, and we also had a puddle issue.. I made these to fix the issue... I put 1 in the front of the slide, and 1 in the rear..
    I used 1-1/4 PVC in 6' sections, a couple of T's, and an eyelet on the end. I use my awning rod to pull out the sections before retracting the slides, no ladder needed to get them out.. I only painted 1 end, since you only see 1 end when it is in place..
    They are very light, easy to carry, and user friendly.. ( to me )
    Joe
  • When we had a long (super slide) with an awning I used two tether balls. They have a rope attached...(Big 5 Sporting Goods store).
  • Here is what I use and it's about 4' long and current version has a rope tied to it so I can simply pull it out from under the awning from the ground. You may need one on each side depending on width of slide out cover.
    Larry
