Tyandkate's avatar
Tyandkate
Shopping for a different tow vehicle.
I currently am using my 15' chevy Silverado 1500 to tow my 07 Jayco 25z bumper pull camper weighing in at 6,000 pounds my truck is rated to pull 10,000. But it pulls my camper like garbage. I have found a 97' Ford F-350 single wheels with a 7.3 turbo diesel. Anyone had any advice on this particular truck? It's a one owner truck with 196,000 miles on it.
  • That's why I'm considering the one ton truck it's longer and built. It's got the 7.3 turbo diesel with a Manual transmission
  • I have the 3.73 rear end with 5.3L V8 I have trouble when on the highway with wind affect. I have a weight distribution hitch set up by the book and two sway bars installed
  • I don't think you're going to be much happier with that old F350 if your problem with the current truck is power.
    What exactly is the issue with the current truck that makes it pull "like garbage?" Maybe we can address that.
    Where did you get the info that said your truck was rated to tow 10,000? My 2015 Silverado daily driver is only rated to tow 6200 per the owner's manual.
    Tow rating depends on engine, transmission, and axle ratio. Mine came with the 3.08 axle ratio, and it seems like most trucks had that ratio. To tow 10,000 with this year truck you need the 3.73 axle ratio.
  • For the most part the 7.3 is a good engine. The rest of the truck I would worry about front end ,trans, brakes and bearings
