ScottG
Jun 17, 2014Nomad
Depending on the design, the slide may only be supported by a narrow strip while it's in. If that is the case then putting much weight on it can bust the strip (what I did) or according to one manufacturer (N. Woods mfg), pull the floor out of the bottom of the slide walls.
So I would support the slide with the 2X4 if you proceed that way.
44,068 PostsLatest Activity: Jun 01, 2026
