danv1317's avatar
danv1317
slide dragging on floor problem
After changing the flooring in my TT, I'm getting the most minimal damage from the bottom of the slide dragging when I pull it in. I see some adjustments on the outside that can lift the far side of the slide up or down a bit. All the drag is in the first 2-2.5ft when the slide goes in. What can I do about this?
  • Actually, those adjustments you found will raise or lower the inside front edge of the slide as well.
    You need to lower the slide at the outer most adjustment. This causes the slide to tip upwards at the front edge when it's in. Kind of a teeter-totter effect.
    You may or may not have enough adjustment to clear the new floor. All you can do is try!
    If this doesn't work then there's a much more complicated plan "B" (That I had to use) that involves adding rollers.
