Reddog1's avatar
Reddog1
Explorer II
Oct 24, 2015
(Snow) Chain Requirements per CalTrans
While search for something else, I stumbled upon the link, Chain Requirements. Among other things, it has a FREQUENTLY ASKED QUESTIONS section. I find it very clear, and easy to read.
I think we TC'ers are more likely to be caught in snow, due to our RV of choice. Many of us pull trailers. While the link is pretty clear on pulling trailers, I saw nothing about flat towing a car. Towing laws for towing a vehicle are very different than towing a trailer.
I have not found the answer for the following question.
1 Flat towing a vehicle with brakes on the towed. The FAQ says required on trailers with brakes, but does not mention Toweds.
I also read; Are cable chains permitted?
Usually. They are permitted for passenger cars and light trucks under virtually all conditions.
They did not define what are considered light trucks. I kinda think maybe our truck with campers might consider not using cable chains. Looks like a maybe okay and maybe not.
Wayne
  • They make cable chains for all vehicles now. Most states approve them. I carry bus cable chains for my 22k GVWR MH.
    BTW. Caltrans says that cable chains are legal on semi trucks and trailers per 605 CVC BUT, travel can be restricted if conditions are bad. Probably because many states totally permit them as a substitute for link chains. Cable chains would be more practical in CA because they are lighter, require less clearance and especially in CA if there is an 1/8 inch of snow they usually reqire chains. The cable chains are much easier to install..
  • Good info.........
    It does define 'heavy duty commercial truck' as one weighing 6500# or more.
    SO don't know what they define as light duty.....??
    Flat towing a car........I would carry set of cable-chains as it is a 'towed' vehicle with brakes (same as trailer)
    And your right.....TCrs would run into this more frequently
    If I got caught in snow it was NOT my doing/intention :B
