rbpru
Aug 08, 2021Explorer II
If you are talking about the stabilizers that you crank down on each corner of the TT; I use a single 12"x 12"x 1/4" sheet of ply wood on loose ground and I lower the stabilizers down directly on concrete and solid asphalt.
Their job is to simply reduce the amount of bounce in the trailer. They are not intended support the trailer. The biggest source of bounce comes from the trailer suspension springs, supporting frame at the corners dampens the bounce somewhat.
