Hybridhunter wrote:
BenK wrote:
To the OP...next time try this and report back on this thread what happened
After a turn or going on a curve, over correct a bit to reset the WD Setup
I think your WD setup is NOT returning to center and is off line a bit in the
direction of the last turn/curve/etc
By going a bit over center to the 'other' direction, think your WD Setup will
be more 'centered' and not impart that 'kink' in the center your setup (at the
ball)
More likely the friction sway than the WD aspect IMO. Easy enough to disable both individually.
Ben is correct because of the hitch brand, and his suggestion should work if the anti-sway is to blame. Personally, I think the anti-sway would normally let go on it's own shortly after the curve without any extra effort to neutralize it.
The OP stated he is now using the Equalizer (Equal-i-zer) brand hitch on this newest trailer. The friction on this brand is built into the hitch by the WD bars more or less permanently binding on their rear attachment:
The friction is produced by the L-brackets rubbing on the WD bars.
Equal-i-zer FAQ page quote:
"My hitch is noisy, what can I do?
The steel-on-steel friction of the Equal-i-zer hitch will always generate some noise. This is not bad, or a sign that there is something wrong with the hitch or setup. In fact, it usually tells you that your hitch is working just like it's supposed to.
You can do several things that usually reduce most of the hitch noise:
1. Try using a set of Equal-i-zer Sway Bracket Jackets on your L-brackets. These were specially designed to help reduce the noise at this joint, without the mess of using grease.
2. Keep your hitch head clean and the sockets lubricated.
3. Re-adjust the angle of your hitch so that the arms sit more parallel with the trailer frame. For example - when your hitch is hooked up, if your spring arms angle up slightly from the hitch head back along the trailer frame, try adding a spacer washer to the hitch head, and lowering the L-brackets 1 hole. This will give you the same weight distribution, but make the arms more parallel to the frame of the trailer."The above quote is taken from
this company page.
For the OP's information, he may note that lubricant (or less messy jackets) may be employed to "loosen" the tension if that is what is causing the off-center tracking. I have doubts that the Equal-i-zer hitch is at fault unless his other hitch also had a stiff anti-sway friction mechanism. He mentioned in his 3rd post that he had a different hitch before with the same result. Only the vehicle is common between the similar problems with the other trailer and hitch.
Hybridhunter, I'm not too surprised that you don't recognize this particular tire characteristic, as most folks don't. It is quite likely that quite a few trucks do steer slightly to the side a bit while towing, but it is generally so light and subtle that most folks don't realize it is occurring. However, the OP is a very observant fellow, and I believe, due to the mild nature of the situation, he is more curious than deeply concerned. It is not rare, but rather common that the steering wheel may hold to one side or another for an extended period, but it is most noticeable during a side wind or aggressively crowned road.
From his picture and description, I found his present Wrangler tires
here. They are only rated for 44 psi max, and he can bump his load rating and gain stability by upgrading to at least a C Load Range tire. I would consider a D, or E Load Range if they are available in this size. Some
searching on the Tirerack site may help guide him for the 275/65-18 sizes.
Wes
