- gmw_photosExplorerIf this was going to be a one shot deal where I was taking it in there for instance for a long term rebuild or similar, I would go to the junk yard and get a set of wheels on the cheap, and put them on the trailer with no tires, and back 'er thru the doorway.
Kinda of a lot of trouble though if a guy wanted to take the trailer in and out a lot. - BumpyroadExplorer
Lowsuv wrote:
the angle of the dangle will probably get you ..
a 10 foot high trailer will not fit because of the lip between the driveway and garage create an issue after the trailer is in until the axles crest the lip .
this particular phenomonom is called a " wedgie " .
unless the approach to the garage and the garage itself are perfectly level there could be a big problem.
bumpy - SuperchargedExploreryes
- TrackrigExplorer IIWhen the same subject came up a while ago, someone suggested replacing the air conditioner with a low profile one to loose a couple of inches.
Bill - LowsuvExplorerthe angle of the dangle will probably get you ..
this particular phenomonom is called a " wedgie " . - rockhillmanorExplorer IIJust make sure you have also figured in the height of your air cond unit too. :W
- Peg_LegExplorerNo one can answer that for you. You'll have to get some one to watch while you "slowly" try it. I stood on the rear ladder once, checking the clearance at a RR tunnel on a back road (had a grass strip between the tire tracks).
Some times doors hang a bit lower than the opening. Maybe you could raise the upper limit. We don't know what kind of trim you have around the door but it's a area that might lend it's self to modifications. - RoyBExplorer IImight want to look at those portable garages...
44,027 PostsLatest Activity: Mar 05, 2025
