covered_wagon's avatar
Jan 03, 2016
Surprising Danger experienced With My HappiJacks
The circuit board went bad on my Happijacks so I had to switch to manual use using the crank. This essentially disengages the electric motor from the gears allowing manual use of the hand crank to the gears for raising and lowering. The surprise came when removing the crank(jack switched in the manual position) when I removed the crank the jack would spin on the weight of the camper and would have gone all the way down and left me crushed under the camper had I not immediately put the crank back in quickly and switched back to the electric mode.
It was very dangerous, both front jacks acting the same, would have also crushed my wife's newer car with me in between.
Just a thought to warn you folks that have nicely lubed your jacks as I have. It would be wrong of me not to inform others about this.
