CKNSLS wrote:
ghostrider42 wrote:
Will you trust Bob?
"synthetic oil thickens less on shutdown your startup will be easier and so will the stress on your engine. This is perhaps the best thing the synthetic class has over the mineral based oils."
http://www.bobistheoilguy.com/motor-oil-104/
Even over at "bobistheoilguy" the conventional wisdom is your motor will not last any longer using synthetic over conventional. As long as you use the right spec.
And if you look at fleet stats that holds true. The California Hwy Patrol uses reclaimed oil for 100K, then taxi fleets buys those cars and put another 100K on them.
See used oil facts-
http://recycling.cityofdavis.org/hazardous-waste/used-motor-oil
Absolutely true....if you also drive and maintain your vehicle just
like Police vehicles and Taxi's...just as found in that old CS report
that so many refer to
I do NOT drive, nor maintain my vehicles just like Police vehicles
nor Taxi's
Believe I drive mine HARDER than they do
Key is that most of them do NOT turn their vehicles off as often as
I do, nor do their vehicles sit 'off' for hours or over nite, but are
kept running most of any 24 hour day.
Similar to that other poster who asked about what NASCAR engines use.
Out of context that too, as who has a 'built' engine that can turn +9K RPM's ?
With that analogy, why not use what super bikes use? They turn in the
+16,000 RPMs and their engine oil a bit more $ than most car engine oils...
You do know that 'most' of all engine wear (normal folks) is from
'dry' starts, right? That then has more weight on the oils film strength
and filter anti-drain-back valve
