brholt's avatar
brholt
Explorer II
Sep 08, 2014
"Temporary" Wired Backup Camera Addition (Ford)
I've been wanting to install a backup camera for some time but hadn't because I wanted it to work with the large Ford display in the console and hadn't gotten around to figuring out the wiring. In addition I thought the perfect location for the camera was over the door of the camper. However, I wasn't at all sure how to route the wires internally through the camper and I really didn't want to start taking the camper apart to figure it out. You have probably heard the saying: "The enemy of the good is the perfect". This last week I decided I should just go ahead and do something and quit worrying about getting it perfect, at least in the first iteration.
I went ahead and ordered this backup camera and harness:
Backup camera (Ford)
It came with a camera attached to a short cable ending in a 4 pin connector, a 32 foot cable with 4 pin connectors on either end, and a 3 foot harness with a four pin connector on one end and the Ford tailgate camera connector on the other.
I went ahead and attached the camera to the railing on the roof using some pipe insulation and two hose clamps:
I then routed the cable across the roof along the railing supports, down between the gutters, down the ladder supports, across to and then down the rear jack, and under the camper to a S clip which gathered up the extra cable and was attached to a hook on the side of the truck bed. The end of the cable was plugged into the harness which plugged into the truck connector. I attached everything using zip ties and was careful in the routing to not interfere with the use of the ladder, awning, or anything else.
I know it's not pretty but for an hours work what a difference. The camera seems to be high quality, it works great and realty makes a difference in maneuvering the truck and camper. Shift into reverse and you have a great big view of what's back there. I just wish I had done it months ago.
Some notes for version #2 when I can get around to making some changes.
- I can't quite see the bumper because of the rolled up awning. I might try rotating the camera mounting horizontally instead of vertically to see if that allows it to see the bumper.
- The camera is high quality but does not have the "distance marks" the tailgate camera has. That would be a plus.
- I'm told that the Ford camera is always on and when you shift to reverse power is applied to a wire from the steering column that runs to the display console to tell it to show the camera instead of the normal stuff. It seems like I should be able to tap into the line and use an upfitter switch to also supply power allowing the display switch to the camera whenever I like. Another project possibility.
- As I noted I thought putting the camera over the door would be an ideal location but I'm not sure how to route the wire behind the plastic strip that also holds the clearance lights (anybody know on an AF?). In looking at the camper I'm wondering why not just mount the camera underneath the Fox Landing?
When flipped up for travel it looks like a pretty good location and maybe somewhat protected from road debris. It would be an easy and clean cable routing. Any thoughts? Is that too low?
Anyway, even at this point I'm pretty happy how my "temporary" backup camera has turned out.
  • languiduck wrote:
    sky_free wrote:
    I did exactly as you are thinking and wired the 15A upfitter switch (3rd from the left) to the camera. Make sure to use a diode (60v, 5A) between the reverse activated power lead on the camera and the source for the reverse activated power so you don't backfeed the system when the switch is on.
    My camera is a license plate camera so it's not as high as yours and it's offset to the left somewhat, but it works fine for me.
    I did the same, having on an upfitter switch is very effective.
    On advice on how to find the wire?
  • Just bought the same cam for my fox. Looking forward to seeing what you come up with.
  • I mounted a hard-wired camera on the back of my camper, and it plugs into the tailgate camera plug on the truck. The image appears on the nav screen in the dash just like the Ford tailgate camera.
    See my posts in this topic for tips and pic's of how I did it, and an image of the Ford schematic for the camera cable.
  • If the camera being centered on the rear wall is not a requirement, see if there is a cavity between your shower enclosure and the bathroom wall to run the wiring.
    I installed the same camera and love it--good image and turns on and off same as the tailgate camera. My Lance 1050s has a plumbing chase between the shower and the rear door--I simply drilled through the rear wall into the chase, ran the wire down below the shower and forward to the left front corner of the camper. Lance emailed a diagram of the rear wall. The camera is mounted above and just to the left of the rear door. It is not far enough off center to be an issue, especially since the camera does not have the centering lines provided by Ford's tailgate camera.
    I also purchased an additional 16 feet of cable which I connected to the tailgate plug harness and permanently mounted under the truck, routing it to the left front corner of the bed, placing the camera connection at the same location as the camper connection.
  • I did exactly as you are thinking and wired the 15A upfitter switch (3rd from the left) to the camera. Make sure to use a diode (60v, 5A) between the reverse activated power lead on the camera and the source for the reverse activated power so you don't backfeed the system when the switch is on.
  • Is this the system they advertised (on their web site) that folks use to put on trucks with salt spreaders and such stuff???????
    Just wondering, because I have been attempting to do the same thing. I found the system mentioned above, with the only drawback I could find being the extremely long cable (30 something feet) that came with it.
