74alex
Mar 07, 2014Explorer
I changed the blade and seal a number of years ago. you should get the
Thetford's exploded view of the toilet and parts. The hard part is to remove the top part. It is set in a groove with a butyl seal material that you have to pry apart.
After this comes apart, 3 springs will fall out. To figure out where they come from you need the exploded view. Each is a different size. One is for the blade seal, the other two fit on top and bottom of the actuator ass'y.
It is not difficult, just time consuming.
Hope this helps.
Alex
Hope this helps.
Alex
