SamBurritos
Aug 08, 2016Explorer
Tongue jack is slanted. Suggestions on how to deal with it?
I have a 2004 Jayco Jay Flight that I bought used a couple seasons ago. I replaced the manual tongue jack with an electric one. It works, but it is slanted back towards the camper and not straight up and down. I uninstalled it and reinstalled the manual jack and found that it is also slanted, but it is not as noticeable since it is shorter. Also, the higher I raise the camper, the more obvious it is that the jack is slanted (see photos below)
When I install the jack, it slides down through the top hole, and then it goes through a second hole in a plate underneath. It seems like those two holes aren't quite lined up.
Looking for recommendations from the group. Am I doing something wrong? Should I rest the jack on a big block so it doesn't have to extend so far?
Thanks!
Photos:
Plate underneath (second hole):
Thanks!
Photos:
