APT wrote:
spoon059 wrote:
Most Tundras have a payload of over 1500 lbs.
I disagree with that. Average double cab may have 1500 pounds per the Tire and Loading sticker. I've never seen a Crewmax with over 1500 pounds. 1200-1350 is the range I have rear, as equipped the way people buy them. Regular cabs make up about 10% of sales mix. No one buys the stripper/base model that each manufacturer lists on web sites and brochures. DC/CM split the rest. For about the same options/features, the Tundra is about 125 pounds lower than Ford/GM. Ram is a further 100 pounds lower.
Per my 2010 Specifications manual;
All regular cab models have minimum 1620 lbs payload up to 2015 lbs for the Reg cab 5.7 4x2. The Reg cab 5.7 4x4 drops to a dismal 1945 lbs payload... terrible "grocery getter" numbers...
The Limited doublecab with 4.6 engine has 1410 lbs, the base doublecab with V6 has 1450 lbs payload, the base doublecab 4.6 engine with long bed has 1340 lbs and everything else starts at 1515 lbs up to 1745 lbs payload capacity.
The Crewmax Limited 4.6 has 1340 lbs payload, up to a max of 1665 lbs payload capacity. 4 of the 8 Crewmax models have payload OVER 1500 lbs, 2 more are at 1450 lbs (close to 1500) and 1 is 1480 lbs (for all intents and purposes... 1500 lbs).
Again... we have no idea what model Tundra the OP has, what engine, what bed size, etc. Seeing as to how a Tundra can have a literal ton of payload, it is either ignorance or blatant stupidity that leads people to say that the Tundra cannot pull the referenced trailer.
The point of my post was that;
#1 We don't have enough info about the truck or the trailer to make an educated decision
#2 The Tundra is offered in plenty of options and has decent payload, similar to what the other manufacturers offer
#3 The Tundra is a good tow vehicle for trailers that fit the specifications of the truck.
Just like any other half ton, the Tundra isn't for everything, but its a quality vehicle with plenty of power and is better than the average RV.net user concedes. I get it, some people don't like imported (Japanese truck made in the USA) and prefer a domestic ("American" truck made in Mexico) because the profits (or whatever GM has since they sure haven't turned a profit in a while...) go to the Japanese CEO's after taxes rather than American CEO's after the same (if not lower) taxes. Some people are brand loyal and would buy a Ford even if it was radioactive and caused cancer in all babies. Some people will only buy Ram trucks even if they all raped nuns. I get it... truck buyers are loyal to a fault... That doesn't mean that the Tundra can't accomplish the same or similar task as must any other half tons...
