GregA's avatar
GregA
Trailer connect
I have a question regarding "Trailer Connect" on my Ford F350.
I have both a 5th wheel and slide-in camper. The 5th wheel seems to just "connect" if the truck is running. The Slide-in camper only "connects" once I press the brake on the truck.
Anyone know why? I'd like for the slide-in to "connect" without depressing the brake. I have my reason I can get into later but in short I want the batteries in the camper to start charging from a remote truck start. Which I think it does with the 5er.
Cheers,
Greg
  • My camper and brakeless trailer are not seen by the Ford or Ram. I believe it must have the brake circuit active and have not seen a difference when the brake pedal is applied. My Ford power wire was ignition enabled while my Ram is always present.
  • StirCrazy wrote:
    I have a 14F350 and my camper doesnt show up at all. I believe it used the brake circut to sence if there is something on it but I am not positive on that. it makes sence though as my camper is the only thing that doesnt show up.
    Steve
    But the lights and power still work, correct?
    OP must be insinuating that that stuff doesn’t work until brake depressed. Which seems odd, although I don’t know how the newer Fords work.
  • I have a 14F350 and my camper doesnt show up at all. I believe it used the brake circut to sence if there is something on it but I am not positive on that. it makes sence though as my camper is the only thing that doesnt show up.
    Steve
  • I’m waiting for the “reason”….lol.
    (Only because there’s no practical benefit to battery charging during a short duration of a remote start)
  • Wire it like Lance does. Skip the trucks harness wiring system. Run an 8 gauge wire from the battery through a 50amp relay to the power pin of a dedicated camper bed plug. Truck on camper charges.
  • Computer constantly sends tiny signal down brake wire to sense trailers brake magnets presence. So it knows automatically.
