genekiwi's avatar
genekiwi
Trailer Tire Wear
I have a Heartland 26rlss 30 feet long. Dual axle.
On one side of the trailer (passenger side), both tires are wearing on the outside. Both tires are wearing the same.
Drivers side is fine. Both tires are wearing the same with no outside or inside wear.
All four tires have the same thread depth on the inside and middle.
I think I can rule out a bent axle since the tires are wearing the same on both axles.
Friend has a theory that since this tires run on the edge of the road, and if the road has a crown, it might be shifting the weight to the outside of the tire. (Not sure about that theory.)
I thought an alignment might be in order but the nearest place that has the equipment is about 90 miles away.
Dry weight of the trailer is about 5800 and loaded it is about 6300. That is a scale weight. GVWR is 8600. I do not believe that I am overloading the trailer.
Side that has the wear is where the fridge and sink are located. I believe I have the tt evenly loaded side to side.
I have always checked tire pressures and kept them at the correct psi, per the tire sidewall and sticker on the trailer.
The tires have not been balanced.
I plan on buying four new tires before heading north this summer. These tires have about 18,000 to 20,000 miles on them.
Any idea as to why I am getting the wear?
Should I just put the new tires on, have them balanced and watch for the wear?
Thanks for any replies.
I have searched the web but I cannot zone in on this particular problem.
  • I can speak from experience. Even through most here will tell you that your axles are bent as well as the axle manufacturer. Most likely NOT. I had the same wear on my tires. Checked axle camber,it was perfect. Put on new tires and no more wear. A trailer builder told me that once in a great while, new tires he puts on trailers wears on outside real fast.
    Put on new tires and go. Just keep a watch on them as you do anyway.
  • Had the same exact TT. Same exact tire wear. It was the alignment. Tech guy said the axle material was soft as they bent back into alignment easy. Dealer tried to say it was the tires, but the tire guy (Goodyear Marathons) said that tires don't just wear on one side for no reason. Alignment cost $195.00 total.
  • How old are the tires? Are you replacing due to the wear or age?
    I suggest you have someone drive your combo down the road while you follow to check that it is tracking straight.
    +1 for belt issues. Inspect and have the tire store inspect those tires when off the trailer.
  • Just do as you plan; new tires and observe. Very unlikely the camber is off enough to cause this or you would see the tire leaning out with the naked eye. If the toe was inward you would have wear on outer edges of both sides.
    Not at all unusual to have strange wear on TT due to weak or damaged belts inside the tire.
  • Overloaded on that side or more than likely you curbed thst side and now have two bent axles/spindles. Get it to a set of scales you can weigh each corner. Then find a truck trailer alignment shop.
