JW2
Oct 13, 2015Explorer
Truck camper dolly thoughts / sanity check.
I have been reviewing my options for a camper dolly. When the camper is off of my truck, the camper and truck sit side by side in a carport on a gravel surface. This surface is somewhat flat, but not perfect, and with a slight slope. My camper weights about 2700 pounds empty but including two batteries, propane, etc. I would not need to move this dolly while the camper would be on it, but I would need to move the dolly when the camper is not on it.
My thoughts: Like most everyone, I do not want to spend a bunch of money on a camper dolly. I did some internet searching and looked at a lot of photos of what other folks are using. Many camper dollies are home built, mostly out of wood and some out of metal, usually having four casters mounted rigidly, one at each corner. These designs would work OK if the surface they are sitting on is perfectly flat, i.e. so that each caster is contacting the surface it is sitting on, such as a concrete floor. However, if the surface is not perfectly flat, as with a gravel surface, the way I see it is with the camper on the dolly, either the camper dolly will flex so that all casters would be in contact with the surface, or if the dolly does not flex, one of the casters will not be in contact and the other three casters will be doing all of the support. Designed for four casters, two supporting the front half of the camper weight and two supporting the rear half of the camper weight, this would mean that if one caster is not touching then the other caster on this end is now supporting ½ of the camper weight by itself.
I like the idea of using a trailer of sorts (a modified boat trailer or something like it). With a trailer having two wheels in the rear located a little aft of the camper center of gravity, and one trailer tongue jack in the front, it would always have these three support points in contact, regardless of how level or flat the surface is, or is not, with the axle carrying most of the weight. The problems I have encountered with finding a trailer is that most of the axles are to wide and I would need to install dually brackets on the camper so that the trailer wheels can fit between the front jacks. I do not want to have to use dually brackets. The few trailers I found that did have a narrower axle width did not have a high enough axle weight rating.
So, in doing all of this I have thought “why not make a wood frame dolly and use 4 Harbor Freight crank up type, 1500 lb each rated, trailer tongue jacks ($30 each) one at each corner.” Using these jacks would allow me to easily adjust for any uneven surface, adjust the height of the camper dolly, and allow the dolly to be rolled out of the way when not being used. Am I crazy? Does this sound reasonable? Anybody else do something like this? Please let me know your thoughts.
Thanks in advance.
Thanks in advance.
