Steve 911 wrote:
Help please. I am looking at two Keystone products. One is a Cougar X-lite 21rbs, and a Aerolite 225 rbsl. If you have any information on either of these units I would greatly appreciate that. I am interested in frame, axle, structure differences if any, or any cautions i should be aware of. Because they are made by the same manufacturer I presume they will be similar. I am looking for a reason to choose one over the other. The Aerolite shows a king bed but I can't find specific specs on that to verify. The brochure I received from Keystone only gives basic info.
Thanks for any input.
Steve
Hi Steve.
Cougar is a Keystone product, but Aerolite is is made by Dutchman RV. Both companys are owned by the parent company Thor industies.(They own many brands including Airstream) But they are seperate companys. you will not find a link to Aerolite on Keystones website and visa versa at Dutchman.
As far as a king bed goes, both trailers are 8ft. wide,so if the aerolite has a true king bed you will have to crawl over it to get in it as there will not be enough room on the side to walk up to it. It is probaly 80" long as opposed to the standard 74" bed that comes in many rv's. I believe the cougar also has a 80" bed.
For specifics on either rv I suggest you contact the companies Keystone and Dutchman (phone numbers are available on their websites) and ask your questions.
As far as quality goes I currently own a Outback by Keystone (Comparable to a Cougar) and have had no problems with it. In the past I have owned a Forest river product and had no problems with that either. You usually only hear from folks with problems and not from satisfied customers. Cougar is also one of the best selling brands of trailers. I have not seen Aerolite in person as we have no dealers with in 250 miles from here.
You may want to check out the forum at www.Keystonerv.org for specific questions on Cougars. Many Cougar owners on there.
Your best bet though would be to go to a dealers lot and see both units in person.
Good luck in your search.
