FishOnOne
Aug 17, 2022Nomad
ksss wrote:blt2ski wrote:
Grit
You should use the whole quote to get context of what I am saying. Not everyone needs a 12-13k gvwr SW truck, be it a 25 or 35 series badge with 400-500 HP.
The OP, fish's neaghbors, myself, need a bit more truck than a typical 15 series at up to 7200 gvw. That's where a modern 8 lug 8600-9200 gvwr rig with 3000+- lbs of payload comes into play. A 250-350hp motor's I mentioned, get decent mileage empty, ride smooth, can pull an ave size RV st 10k 5w and upwards of 15k ball mount.....this truck does not exist anymore. I consider bad, some may consider it good.....
If Frod would build more of it 8200?!?! G wr f150's I think many more than does would sell. If I could have found one, that would be better than my GM1500. Reality, with the 1800 lb tear helper I put on my truck, I'm better off.
My 02.
Marty
On the surface, I have always agreed with this thought. However, the reality of it is these trucks when they have been released don't seem to do well enough to stick around. GM had the 1500 HD which didn't last. I think Nissan built their Titan around this principle. The diesel version had power specs identical to the GM LB7. HD undercarriage and so forth. Obviously now, the entire Titan line is going away. There were other issues with the Titan beyond its spec sheet but come to find out, most will just buy more truck, even if they only need a portion of its capacity. The price of the truck and the MPG in these trucks don't justify the reduced capacity. I have coined this before, but it fits here as well. "A lot can always do a little, but a little can never do a lot". When it comes to people actually signing on the line, this seems to ring true.
And a lot of people buy a truck for something they may or may not do and usually ends up may not do.
44,071 PostsLatest Activity: Aug 16, 2026
