limitswitch's avatar
limitswitch
TV upgrade?
We have a F150 TV, 27' TT total weight around 7600lbs. Reese DC anti-sway WD system. all of my weights are good after I have been over the scales. My max trailer weight for the pickup is 8000#. The truck has 3.31 gears. We are thinking about upgrading to an F250. Will pulling the TT be better with a 3/4 ton pickup especially in windy conditions?
  • Yes, the F250 would make a better overall tow vehicle! It will be heavier, with heavier suspension, much stronger frame, more stable E-rated tires, all of which will help in windy towing. It will also come with a lower geared differential, great towing mirrors, and an integrated brake controller.
    The downside is more fuel cost, when not towing, and a stiffer ride. If your truck is a daily driver, and you don't tow often, or long distances, you have to decide if a HD tow vehicle is what you want.
    I enjoy driving my 250, get about 8-10 mpg towing, and about 15 mpg empty at 65-70 mph.
    Jerry
  • I have checked the weight with both of us in the TV. We are not at max but we are less than a 1000#'s from the GCWR. The F150 pulls ok until we get on a steep grade or a heavy cross wind (that is when the white knuckles show up), but I am not in any hurry where I go anyway. We were just wondering if the heavier F250 would help out on windy conditions.
  • As a rule bigger is better because you have more capacity to spare, particularly on your max cargo capacity.
    Most TVs can pull a lot more then they can carry. I think you will find your loaded for the trip tongue weight is at least 800 or 900 lbs. That does not leave a lot for people and gear.
    Check the change in truck weight with and without the trailer and see how much cargo capacity you have left.
