pcoplin
Sep 02, 2015Explorer II
Upper Stable Load spacer
2001 Ford F250, stock upper overload with StableLoads. The front one is hard on the leaf when the camper is on, the rear one just touches, and slaps the leaf when hitting bumps. So I made a couple spacers for the rear set out of 3/8.
Before
After
However I did call the local spring shop, and they sell a heavy duty upper overload leaf set (4 leaf) that replaces the stock ones. It also has a rubber pad on the end. It may be enough to remove the Stableloads and still have a heavier overload. I like this option because the ride unloaded will be the same.
Before
After
