David_LaBrie's avatar
David_LaBrie
What towing options on an F-150?
I am going to be buying a new F-150 soon and then possibly a new R-Pod Travel trailer. What options should I get on the truck so I will be ready to tow when I buy my new rv? The R-Pod specs are:
Dry Hitch Weight-292 lbs.
Unloaded Vehicle Weight-2756 lbs,
Cargo Carrying Capacity 1036 lbs.
I would like to set the truck up for this or maybe a slightly larger RV.
Thanks.
  • kerrlakeRoo wrote:
    pfidahospud wrote:
    The factory tow mirrors are definitely worth the $$$ in my opinion.
    good point, I agree.
    They are oversized, awkward, and not drive through or parking friendly. There are a myriad of good clip on's I would suggest before those.
    Ford Integrated TBC is a must have though.
    Somewhat predictable on this site to have a 3/4 suggested lol. WOW. Not a good read of what the OP has in mind with an Rpod.
    Pretty much any F150 will work for what the OP has in mind and much more. For example, a plane jane 5.0 4x4 with tow package is good for over 8K lbs. LOTS of room for an upgrade or 2. The only thing to watch is the 2.7Eco models usually only have around 1600# payload.
  • Have you considered going with a 3/4 ton now? You will get the bug for more room, and want to get something larger and heavy. I have read more posts on these Forums about someone with a 1/2 ton and can't tow what they want, or already purchased. Sometimes when you try to add spring upgrades, shocks, bags, tires-wheels, etc, you end up spending more than a 3/4 ton from the start.
  • I wish I had factory tow mirrors but the slip ons are okay. Buy a beefy F150 for the future and resale.
  • On a trailer that small, any new F-150 will be capable of towing it. But if any possibility exist of going with something bigger in the future, I'd look at a tow package and an engine upgrade from the base model.
