rjstractor
Dec 28, 2017Nomad
The trucks are so similar mechanically (especially the diesel version) that I personally think it's silly that Ford and other manufacturers build the 250 and 350 SRW. The 350 has higher numbers, an overload spring set (available on the 250), maybe a little bit bigger tires and a spacer block. Nearly all the nuts and bolts are the same. There's a reason the 350 only costs a little bit more. Having said that, get the 350. If marketing made any sense, the F350 SRW would be come the F250 and the F350 would be DRW only. Same goes for other makes. Ram could probably beef up their coil suspension to meet the current 3500 SRW specs.
