Buzzcut1 wrote:
Kayteg1 wrote:
Maybe you drive on better roads, but my dually gets airborne on CA freeway bumps every few minutes.
Quite often my Cruise Control will disengage becouse computer thinks I am involved in accident.
So the rear blocks like that sooner or later would find their way to jump out the sides.
I have no blocks on the rear, but on front I have all the blocks screw to a plywood that front of the camper sits on.
I need the plywood shimming to clear the roof lights on the truck, so it is working for me very well.
I don't consider rear blocks very important, but would be happy to find a way to secure them there.
Ever notice how the opening of the tailgate is narrower than the rest of the bed and that the tc fits through that opening with a 1/2" on each side at the top and 4" at the bottom? So just how is a 2x4 hooked to a big wedge ( thats makes a 8" wide assembly) jammed up to the side of a camper which is held in place by properly tightened tie downs (front and rear) going to bounce or slide out of that tiny little gap?
Buzzcut.... your ability to visualize is very good...
... if you had cables attached to any of the 5 assemblys... ( ie; front, front corners, and rear sides ) and the cables hanging over the sides where you could use them to try to pull the pieces out.... you couldn't do it.
I can assure anyone, I'm not the brighest bulb in the world.... but my ideas are usually so simple that they don't fail.
This is one of the simplist....
assists alignment, position, and prevents skewing.
"IF" the camper was to bounce up off the bed and then drop back down it would fall (repositioning)into it's proper place.... the whole truck bed as been transformed into a "funnel"... the bottom of the camper fits with only a 1/2" of movement possible
It's not a rubeX cube... just look at the essential pieces... the slopes... then attach themial pieces to some thing that will position them and keep them from turning over. Position them so that they can't move with the campers bottom can't move anywhere except where you want it to be.
Help, someone....
If it doesn't work I wouldn't't publish it...
I get enough grief on the forum that I don't offer many ideas on the TC forum now.
Chet
