riah
Dec 18, 2020Explorer
2003AF990 battery conversion from lead acid to LiFePO4
Hi,
I'm still trying to figure out electrical systems, so bear with me as I'm really green with the dual use solar and batteries in RVs.
Has anyone tried to fit a Big Battery 24V LiFePO4 battery block into the battery box location on their (2003) AF 990? [We are trying to figure out if that is even an option (vs ordering 2 Big Battery 12V LiFePO4 battery blocks.]
Although I'm confused if we would be better off with 2 12V battery blocks, as that would give us 340 Amp hours vs 170 Amp hours, correct? Or is it the 24V equivalent to the (2) 12V batteries together.
Also, what modifications would one need to do to get it to work? - as right now I believe it is set up as 12V system, not 24V.
Our solar battery controller is an EPEVER MMPT 30 AMP 12V/24V auto solar charger and right now we have 200 Watts of solar currently installed (with 200 Watts additionally available to add this current setup, for a total of 400 watts.)
[Also, I presume I would need to reprogram the solar charger as well? If so, I'll also need to get the adapter to be able to make programmatic changes, as well as the temperature sensor too.]
So, that said, what would y'all do? Just order 2 12V battery blocks? or a 24V battery? Please advise! TY!
