daveor's avatar
daveor
Above mirror light
Wife says she needs a light above the mirror on the medicine cabinet in the trailer, there is plenty of room to mount one there, trouble is,, no way to run trailer power to it, also, she is short so would have to have some kind of switch down lower to turn on. Thinking maybe some kind of LED light using flashlight type batteries,, Anyone got any suggestions? Thanks.
  • Awesome,
    Thanks, that looks perfect! Less than 20 dollars and has a remote! Perfect!
  • solved my problem,,, found this at Home Depot this morning,,
    http://www.homedepot.com/p/Hampton-Bay-LED-Bar-Night-Light-with-Remote-LPL1014WRCTHD/205319619?keyword=070686508350#product_description
    8 bulbs, 3 AA batteries and a remote, the light bar also swivels.
  • The Logans wrote:
    You're right, there is no way to pull power through the walls or ceiling, because of all of the insulation.
    Actually, running wiring in the ceilings and walls (except walls with solid foam insulation) is fairly easy. I've done a LOT of it now.
    Insulation is not placed so that it fully fills a ceiling cavity. The factory runs all the wiring loose in the ceilings and it just lays on top of trusses under the blanket of insulation. Often, the insulation is poorly done anyway and there's lot of voids. You may not even find any near exterior walls. It's surprisingly simple to add wiring once you've tried doing some - romex, coax or LV wiring.
    For lighting at the mirror, I suggest installing one or two "puck" style LED lights in the ceiling so you won't have to get wiring into a wall. Cheap on ebay. Check lumen output first tho. Our TT has two factory installed puck lights over our mirror and they do a good job of lighting. Could be a little brighter tho. I added a puck light in our shower (it was too dark) and maybe you could do the same while adding lighting over the mirror.
    To run wiring in the ceiling, pull down lights, AC grilles, skylight trim, speakers, etc. to give access into the ceiling cavity. Use coat hanger wire or a fish tape (cheap at HF) to leapfrog the wire from access point to access point. If needed, you can enlarge the hole behind a surface mounted light to give easier access as the light will cover the hole. I've fished as far as about 6' through the ceiling in one go. You probably won't need to, but wiring can also be run inside cabinetry, under showers & tubs, inside fridge enclosures, etc.
    If you have something mounted on a wall like a switch, receptacle or holding tank monitor panel, there is most likely an existing hole in the top plate right above that the factory used to get wires from the wall into the ceiling. If installing a small wire/cable and not romex, you can probably run the wiring through the existing hole no problem.
    Good luck and don't give in too easily!
  • TUCQUALA wrote:
    Bought a couple of GE 3 led batt powered lights at Home Depot. Put one on each side of the cabinet/mirror. Bright, but no shadows when shaving!! Basically just for that purpose. They have a "touch" switch.
    Link: http://www.homedepot.com/p/GE-6-in-Battery-Operated-LED-Under-Cabinet-Utility-Light-Fixture-17542/204663927
    See now that they are 2 led, 3 led version discontinued, although there may be some still out there in some stores stock.
    I checked our local store,,says they still have some 2 bulb in stock,, will have to do some measuring and make sure they will fit,, not much room on the left side of the mirror.. Might be able to mount on the door frame beside the mirror, thinking about calling super bright leds and see if they have something that would work,,, maybe an LED strip light on each side with a battery pack that would fit inside the cabinet. Think LEDs are the way to go though. Thanks every one for the response.
  • Bought a couple of GE 3 led batt powered lights at Home Depot. Put one on each side of the cabinet/mirror. Bright, but no shadows when shaving!! Basically just for that purpose. They have a "touch" switch.
  • A battery unit with LED lights will last a LONG time. That's what I would do, rather than bother with wiring. LEDs are ideal for this type of application due to their low energy use.
  • We've got the same issue, can't even see my face to shave. I wonder what dummy decided to place the light behind the head, so the face is in shadow?
    You're right, there is no way to pull power through the walls or ceiling, because of all of the insulation. I hate to rely on a self powered unit, because the batteries don't last long... Well, guess that I could run a wire on the surface, and then put a stick-on wire cover over it...
  • Not sure if it would be bright enough, but what about those under cabinet light strips for the kitchen. Might be able to mount above the mirror or put one on either side if there is room and plug them in. I bought a do it yourself kit and it came with the plug end. You cut the wire to however long you need, then attach the plug for the receptacle.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
