StirCrazy
Mar 31, 2021Moderator
How to build a LiFePo4 battery bank.
A lot of people dont have any idea how easy it is to build a DIY LiFePo4 12V battery so I'll post a deicent video of how to do it so people can decide for themselves if it is in there capability.
this video is pretty decient on how to do it, what is missing is some sort of case. the Prismatic cells like to be clamped togeather slightly if you going to be running high currents. I have seen cases made out of wood with threaded rod providing the pressure, and several other ways also.
also I am not a fan of the BMS he uses, there are lot better ones, but he explains he needed the high capacity one to do a torture test on the cells.
so he builds a 280Ah 12V battery in this video, if you need more you could build 2 and then just tereat them like two 12V batterys and run them in parralell, or just build it all in series and do a 24V set up if you want to do the higher voltage systems.
280Ah LFP build
Steve
280Ah LFP build
Steve
